Turn a 2.5" SATA HDD/SSD into an external SuperSpeed USB 3.0 Hard Drive/Solid State Drive. The SAT2510BU32 2.5-inch SuperSpeed USB 3.0 SATA Hard Drive Enclosure turns a normal 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into a portable, external hard drive.
Connecting to a host computer through USB 3.0 with no external power required, this enclosure supports full SuperSpeed USB data transfer speeds up to 5 Gbps - 10x faster than the USB 2.0 standard, and is backward compatible with older USB connections (USB 2.0). Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Featuring a lightweight, portable design this USB 3.0 SATA HDD enclosure is constructed of aluminum, which offers maximum durability and operating heat dissipation.
- StarTech.com 2.5in USB 3.0 SSD SATA Hard Drive Enclosure - Storage enclosure with power indicator - 2.5" - SATA 3Gb/s - 3 Gbit/s - USB 3.0 - black - SAT2510BU32 - storage enclosure - SATA 3Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Power indicator
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, aluminium
- Power Source
- USB bus
- System Requirements
- Linux, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- 7.5 cm x 12.3 cm x 1.25 cm
- 180 g
- 2-year warranty
- 2.5"
- Host Bus
- USB 3.0
- Product Material
- Black
- Power indicator
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- 1
- Processor
- ASMedia ASM1051
- Bays
- 1 x SATA 3Gb/s - SATA combo
- Connections
- 1 x USB 3.0
- Included Accessories
- USB (power) cable
- Tested with up to 1TB 5400 RPM hard drives
- Plug and Play, FCC, RoHS
- Power Source
- USB bus
- OS Required
- Limited warranty - 2 years
- 7.5 cm
- 12.3 cm
- 1.25 cm
- 180 g
- 0 °C
- 60 °C
- 10 - 90%
StarTech.com 2.5in USB 3.0 SSD SATA Hard Drive Enclosure | In Stock | £21.83 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £35.75 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £29.35 |
StarTech.com USB 3.1 2.5 SATA Enclosure USB-C USB-A | In Stock | £32.26 |
StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £64.78 |
