StarTech.com 2.5in USB 3.0 SATA Hard Disk Drive Enclosure for SAT2510U3REM
Quicklinx: 8JFJWS00 Mfr#: SAT2510U3S
  • Windows 8 (32/64 bits)
Turn a 2.5in SATA HDD/SSD into an external USB 3.0 drive while also an additional or replacement removable enclosure for the SAT2510U3REM. The SAT2510U3S 2.5in Hard Disk Drive Enclosure for SAT2510U3REM is a spare SATA drive enclosure for use with the SAT2510U3REM Removable Hard Drive Backup System/Mobile Rack, which simplifies removing/rotating drives, and is also backward compatible with the USB 2.0 model, SAT2510U2REM.
This 2.5" SATA enclosure allows for native SATA connectivity (SATA 6 Gbps compliant) while mounted inside the SAT2510U3REM backup system, but also provides SuperSpeed USB 3.0 connectivity (with up to 5 Gbps of data bandwidth) when used externally.
StarTech.com 2.5in USB 3.0 SATA Hard Disk Drive Enclosure - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB 3.0
Storage enclosure - external
Bus Type
SATA 6Gb/s, USB 3.0
Expansion Bays
1 x internal - 2.5" x 1/8H
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Product Material
Plastic, aluminium
Power Source
USB bus
Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
7.91 cm x 13.28 cm x 1.59 cm
120 g
P/N: S251BU31REM
2.5"
Host Bus
SATA 6Gb/s, USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
ASMedia ASM1053 / ASM1456
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin Micro-USB Type B
1 x USB 3.0 cable - external
Mounting Kit
Included
FCC, RoHS
Power Source
USB bus
7.91 cm
13.28 cm
1.59 cm
120 g
0 - 95%
P/N: S251BU31REM
