StarTech.com 2.5in USB 3.0 External Hard Drive Enclosure with Virtual ISO Portable External SATA HDD
Quicklinx: 8XBZWS00 Mfr#: S2510BU3ISO
  • Windows 8 (32/64 bits)
ISO drive emulation is an ideal solution for computers that do not have optical drives (i.e Ultrabooks™, Netbooks). Using hardware based ISO emulation, the S2510BU3ISO USB 3.0 HDD Virtual ISO Enclosure allows you to easily create and mount up to 3 different virtual Blu-ray/DVD/CD ROM images, ensuring maximum performance while eliminating the hassle and expense of complicated virtual ISO software.
This enclosure lets you turn almost any 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an external virtual ROM drive through a USB port (optimal performance with USB 3.0, backward compatible with USB 2.0).
The enclosure supports large capacity hard drives (tested with up to 1TB), and also doubles as a standard external hard drive enclosure that can be used to maximize system storage expansion and backup capabilities.
The S2510BU3ISO virtual ISO HDD enclosure is backed by a StarTech.com 2-year warranty and free lifetime technical support.
The StarTech.com Advantage
-Hardware based ISO emulation is fast and platform independant, requiring no software or driver installation
-SuperSpeed USB 3.0 allows for up to 5Gbps of data bandwidth for faster data transfers, while remaining backward compatible with USB 2.0 systems
StarTech.com 2.5in USB 3.0 External Hard Drive Enclosure with Virtual ISO - Portable External SATA HDD - storage enclosure - SATA 3Gb/s - SATA 3Gb/s, USB 3.0
Storage enclosure - external
Bus Type
SATA 3Gb/s, USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Product Material
Plastic
Power Source
USB bus
Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
13.5 cm x 7.8 cm x 1.6 cm
75 g
P/N: USBDUP15, USBDUPE115, USBDUPE17
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
SATA 3Gb/s, USB 3.0
Product Material
Plastic
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Fujitsu MB86C311
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA combo
1 x USB 3.0 - mini-USB Type B
Pouch
1 x USB cable - external - 78.7 cm
USB powered, LED indicator, tested with up to 1TB 5400 RPM hard drives, 3 virtual ISO images
FCC, RoHS
Power Source
USB bus
13.5 cm
7.8 cm
1.6 cm
75 g
60 °C
5 - 90%
8XBZ StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
8XBZ StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
8XBZ StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
8XBZ StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £53.18
