The SAT2MSAT25 2.5in SATA to Mini SATA SSD Adapter Enclosure turns an mSATA (Mini SATA) mini-SSD into a standard 2.5in SATA SSD for use anywhere a 2.5in SATA drive can be used. Featuring all of the standard mounting points that a normal 2.5in hard drive uses, the converter can be installed into External Hard Drive Enclosures, Hard Drive Docking Stations or into desktop or laptop computers. The enclosure also features a unique design that enables seamless data pass-through with no conversion bottlenecks, enabling the mSATA drive to work as fast as it's allowed by the host system/interface.
- StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure - Mini PCIe ssd Adapter - SATA to mSATA - Mini PCIe SATA (SAT2MSAT25) - storage enclosure - SATA
- Storage enclosure - external
- Bus Type
- SATA
- Silver
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Devices
- Hard drive
- Channel Qty
- 1
- Product Material
- Plastic, aluminium
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista
- 6.8 cm x 9.8 cm x 1 cm
- 50 g
- 2-year warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
- 2.5"
- Host Bus
- SATA
- Product Material
- Silver
Storage Controller
- Supported Devices
- Hard drive
- Channel Qty
- 1
- Processor
- No CPU
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 storage - Serial ATA-300 - 52 pin mini-SATA
- RoHS
- OS Required
- Limited warranty - 2 years
- 6.8 cm
- 9.8 cm
- 1 cm
- 50 g
- 0 °C
- 50 °C
- 50 - 95%
- Designed For
