StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter
Quicklinx: 7TGLWS00 Mfr#: 25SATSAS35
10 In Stock
£13.55 ex VAT
£16.26 inc VAT
Turn Virtually any 2.5" SATA or SAS Hard Drive into a 3.5" SATA Drive. The 25SATSAS35 2.5-inch SATA/SAS to 3.5-inch SATA Hard Drive Converter converts a 2.5-inch SATA or SAS hard drive (HDD) or solid state drive (SSD) into a 3.5-inch form factor SATA Hard Drive.
The converter provides a versatile solution for 2.5-inch drive installations, enabling you to install a 2.5-inch SATA/SAS drive in a 3.5-inch bay, drive drawer caddy/tray, or into a 3.5-inch drive enclosure.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Suitable for drives with a height of up to 15mm, virtually any 2.5-inch SATA or SAS hard drive can be made to look and function like a 3.5-inch hard drive - complete with standard mounting points along the sides and bottom (including 3 points along the sides for compatibility with some Dell systems).
The Drive Converter features a trayless design for simple drive installation and removal, and is constructed of durable, yet lightweight plastics, with ventilation openings to aid air flow and help keep hard drives running cooler.
  • Versatile form factor compatibility
    This adapter supports a conversion from standard 3.5-inch bays to accept 2.5-inch SATA/SAS SSDs and HDDs, providing flexibility for various storage needs.
  • Robust and reliable material
    Made from high-quality plastic, this storage bay adapter ensures longevity and durability in demanding environments, maintaining performance.
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter - Storage bay adapter - 3.5" to 2.5" - black - 25SATSAS35 - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Plastic
10.1 cm x 14.6 cm x 2.5 cm
135 g
P/N: IDE2SAT2, S352BU33HR, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
Storage bay adapter
3.5" to 2.5"
Product Material
Plastic
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
FCC, RoHS
10.1 cm
14.6 cm
2.5 cm
135 g
7TGL StarTech.com 24" Serial ATA Cable In Stock £5.28
7TGL StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
7TGL StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
7TGL StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
7TGL StarTech.com 6in SATA Serial ATA Cable In Stock £3.61
7TGL StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
7TGL StarTech.com 6in Latching SATA Cable In Stock £2.60
7TGL StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
7TGL StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
7TGL StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
