Turn Virtually any 2.5" SATA or SAS Hard Drive into a 3.5" SATA Drive. The 25SATSAS35 2.5-inch SATA/SAS to 3.5-inch SATA Hard Drive Converter converts a 2.5-inch SATA or SAS hard drive (HDD) or solid state drive (SSD) into a 3.5-inch form factor SATA Hard Drive.
The converter provides a versatile solution for 2.5-inch drive installations, enabling you to install a 2.5-inch SATA/SAS drive in a 3.5-inch bay, drive drawer caddy/tray, or into a 3.5-inch drive enclosure.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Suitable for drives with a height of up to 15mm, virtually any 2.5-inch SATA or SAS hard drive can be made to look and function like a 3.5-inch hard drive - complete with standard mounting points along the sides and bottom (including 3 points along the sides for compatibility with some Dell systems).
The Drive Converter features a trayless design for simple drive installation and removal, and is constructed of durable, yet lightweight plastics, with ventilation openings to aid air flow and help keep hard drives running cooler.
- StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter - Storage bay adapter - 3.5" to 2.5" - black - 25SATSAS35 - storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Plastic
- 10.1 cm x 14.6 cm x 2.5 cm
- 135 g
- 2-year warranty
- Designed For
- P/N: IDE2SAT2, S352BU33HR, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
- 3.5" to 2.5"
- Product Material
- Plastic
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- FCC, RoHS
- Limited warranty - 2 years
- 10.1 cm
- 14.6 cm
- 2.5 cm
- 135 g
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.26 |
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £3.01 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.44 |
StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.56 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.44 |
StarTech.com 6in Latching SATA Cable | In Stock | £5.08 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £13.64 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £23.27 |
