StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit
Quicklinx: 5D2XWS00 Mfr#: BRACKET25SAT
Mount a 2.5in SATA hard drive to any desktop with an available 3.5in bay. This Serial ATA hard drive mounting kit allows you to install a 2.5in SATA hard drive in a 3.5in drive bay. The 2.5in to 3.5in SATA hard drive mounting kit features a sturdy aluminum bracket, as well as a combined 7+15 pin SATA + LP4 Power to SATA cable - which helps simplify installation and reduce clutter within the computer case.
  • Robust construction
    The SSD mounting bracket is made from aluminum, providing strong and stable support for your SSD while ensuring lightweight handling during installation.
  • Simple installation
    Designed for easy setup, the bracket allows users to securely mount a 2.5-inch SSD in a 3.5-inch hard drive bay without requiring complicated tools or procedures.
  • Environmentally compliant
    This product meets RoHS standards, confirming its use of environmentally friendly materials and processes, making it a responsible choice for modern computing needs.
StarTech.com SSD Mounting Bracket - Solid Metal - 2.5in to 3.5 Hard Drive Adapter - SSD Bracket - SSD Upgrade Kit (BRACKET25SAT) - storage bay adapter
Storage bay adapter
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Aluminium
9.8 cm x 10 cm x 1 cm
110 g
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
Storage bay adapter
Product Material
Aluminium
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
1 x Serial ATA cable - internal
RoHS
9.8 cm
10 cm
1 cm
110 g
5D2X StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.96
5D2X StarTech.com 18in SATA Serial ATA Cable In Stock £2.56
5D2X StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £2.95
5D2X StarTech.com 36in SATA Serial ATA Cable In Stock £5.56
5D2X StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.79
5D2X StarTech.com SATA to LP4 Power Cable Adapter In Stock £3.80
5D2X StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £25.77
5D2X StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.21
5D2X StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.12
5D2X StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £19.99
5D2X StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.53
5D2X StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £22.60
5D2X StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay In Stock £16.09
