Securely mount a 2.5in IDE hard drive into an available 3.5in bay in your computer system. This Drive Bay Mounting Bracket Kit lets you mount a 2.5in hard drive in a 3.5in drive bay, allowing you to maximize the internal space-efficiency of your computer case.
- StarTech.com 2.5in IDE Hard Drive to 3.5in Drive Bay Mounting Kit - storage bay adapter
- Storage bay adapter
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Metal
- 2-year warranty
- 3.5" to 2.5"
- Product Material
- Metal
Storage Controller
- Processor
- No CPU
- Bays
- 1 x storage
- Connections
- 1 storage - 40 PIN IDC
- Compatible Bay
- 1 x internal 3.5"
- Mounting Kit
- Included
- RoHS
- Limited warranty - 2 years
