StarTech.com 2.5in and 3.5in 40 Pin Male IDE to SATA Adapter Converter
Customer rating: 5.0* (Write a review)
Quicklinx: 5CB9WS00 Mfr#: IDE2SAT
Connect your SATA drive to an IDE motherboard. This IDE/ATAPI to SATA adapter lets you connect a SATA drive to a motherboard IDE/ATA 33/66/100/133 port. The IDE/SATA adapter offers a cost-effective solution for bridging the gap between a newer SATA drive and older motherboard designs, allowing you to connect newer SATA drives to an older IDE motherboard port and in turn eliminating the need to upgrade the motherboard for the sake of compatibility with the drives.
Saving time and hassle, the IDE to SATA adapter can be connected through simple plug and play installation.
StarTech.com 2.5in and 3.5in 40 Pin Male IDE to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Max Storage Devices Qty
1
P/N: BRACKET25X2
Storage controller
Host Bus
Ultra ATA/133
Storage Controller
SATA 1.5Gb/s
1
1 x SATA 1.5Gb/s - SATA combo
1 storage - ATA-133 - 40 PIN IDC
FCC, RoHS
Limited warranty - lifetime
P/N: BRACKET25X2
5CB9 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.52
Customer reviews
Write a review for the StarTech.com 2.5in and 3.5in 40 Pin Male IDE to SATA Adapter Converter here!
Boot to SATA from old drive
Reviewed by Robert Govier. Review Posted 02/04/2009
I have an old Shuttle SN41G2 with only IDE connections, which I wanted to upgrade with a big hard drive. I didn't want to spend my money on a drive I couldn't transfer to a new computer in the future, so I purchased a SATA drive from Dabs and a Pata to Sata cheap from ebay. After getting two adapters DOA from Hong Kong I decided to spend a bit more on this item from Dabs. This was the right move! The adapter allows me to boot into Windows XP from the SATA drive with no additional drivers required. I haven't noticed any speed issues, and the adapter is small enough to fit inside even the cramped shuttle case. My only criticism... £20 seems high but I guess that comes with peace of mind from buying from a UK retailer with a good reputation!
  • Overall 5*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
