Turn a 2.5" SATA Hard Drive or Solid State Drive into a UASP supported USB 3.0 External Hard Drive. The S2510BMU33 USB 3.0 Hard Drive Enclosure with UASP lets you connect a 2.5in SATA III hard drive (HDD) or solid state drive (SSD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 2.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 1TB) this HDD enclosure is compatible with virtually any 2.5in SATA hard drive, and greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure requires no external power adapter and features high quality aluminum construction, ensuring both portability and durability when carried as a laptop accessory.
Improved Performance with UASP
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com enclosure, and a SATA III solid state drive.
- StarTech.com 2.5" Hard Drive Enclosure - Supports UASP - SATA 6Gbps - USB 3.0 External Hard Drive Enclosure - SSD/HDD Enclosure (S2510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 5 GBps
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium, plastic
- Power Source
- USB bus
- System Requirements
- Apple MacOS X, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Linux
- 7.7 cm x 12 cm x 1.55 cm
- 97.7 g
- 2-year warranty
- Designed For
- P/N: HB30C1A1CPD, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, USBDUP15, USBDUPE115, USBDUPE17
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.0
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 5 GBps
- Supported Devices
- Hard drive
- 1
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Cables Included
- 1 x USB cable - external - 45.7 cm
- USB powered, LED indicator
- Mounting Kit
- Included
- RoHS
- Power Source
- USB bus
- OS Required
- Limited warranty - 2 years
- 7.7 cm
- 12 cm
- 1.55 cm
- 97.7 g
- 10 - 90%
- Designed For
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.32 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £9.23 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £20.58 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £26.90 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £19.09 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £26.26 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £27.56 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £35.55 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.06 |
StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £50.65 |
