StarTech.com 2.5Gbps PoE Network Card
Quicklinx: J4LQWS00 Mfr#: PR22GIP-NETWORK-CARD
£161.84 ex VAT
£194.20 inc VAT
This 2.5 GbE network interface card (NIC) features dual Intel I225-V chipsets with Intel vPro technology to enhance performance and data integrity. The variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support for both new and legacy network hardware. Utilize existing CAT5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration. The PCIe Ethernet card supports the IEEE 802.3af and IEEE 802.3at (Type 1 and Type 2) standards for Power Sourcing Equipment (PSE) and can deliver up to 48V DC and 25.5W of power per port to compliant Powered Devices (PD). This flexibility eliminates the need for a separate power supplies or PoE injectors for remote networked devices such as IP cameras, access control devices, remote kiosks, and wireless access points. The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment. The network interface card connects through an available PCI Express x2 2.0 (or higher) expansion slot. The card ships with a standard-profile bracket pre-installed and includes a low-profile bracket for installation into small form factor systems and servers. This ethernet NIC card is compatible with Windows, Windows Server, VMware, and Linux. This card supports the following advanced features: PXE Boot, WoL, VLAN tagging, 9K jumbo frame, full-duplex, and Intel vPro technology.
  • Power Over Ethernet
  • Increased Network Speed
  • Enhance Existing Hardware
StarTech.com 2-Port 2.5Gbps PoE Network Card, Intel I225-V, 802.3af/at - network adapter - PCIe 2.0 x2 - 10M/100M/1G/2.5 Gigabit Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x2
PCI Specification Revision
PCIe 2.0
Ports
2.2 cm x 18 cm x 12.1 cm
111 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 9000
Intel I225-V
IEEE 1588 PTP, IEEE 802.1as, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1x, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bz, IEEE 802.3i, IEEE 802.3u, IEEE P802.3az
Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux 5.8.x or later (LTS versions only), VMware ESXi 7.0
Network adapter
Plug-in card
PCI Express 2.0 x2
PCIe 2.0
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity, link/speed, PoE
QoS, VLAN support, AVB, WOL, EEE, Auto MDIX, PXE boot, full duplex capability, promiscuous mode, bus powered, built-in heatsink, auto-negotiation, PSE
Processor / Memory
Intel I225-V
2 x 2.5Gb Ethernet - RJ-45 - female , 1 x LP4 - 4 pin power - female , 1 - 8 (6+2) pin power - female
Low-profile bracket
RoHS, WEEE
2.2 cm
18 cm
12.1 cm
111 g
Shipping Width
3.8 cm
Shipping Depth
20.7 cm
Shipping Height
14.4 cm
55 °C
5 - 90% RH
J4LQ StarTech.com 1-Port 2.5Gbps PoE Network PCIe Card In Stock £86.01
Wired / Wireless: Wired
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: 2.5 Gigabit Ethernet
Type: Network adapter
