StarTech.com 2.5" SSD/HDD Mounting Bracket
Quicklinx: CHMZWS00 Mfr#: BRACKET125PT
Accessory Type: HDD Enclosure
27 In Stock
£4.35 ex VAT
£5.22 inc VAT
Easily install one 2.5" solid-state drive or hard drive into a 3.5" bay, without requiring any additional hardware or tools. This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height.
The mounting bracket's tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It's ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects.
The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs.
  • Effortless installation
    The 2.5" HDD / SDD Mounting Bracket for 3.5" Drive Bay features a toolless design, allowing for quick and easy installation without the need for additional tools. This hassle-free setup makes it an ideal solution for upgrading your PC storage with speed and ease.
  • Versatile compatibility
    Designed to fit both 2.5" HDDs and SSDs into a 3.5" drive bay, this adapter bracket ensures a seamless fit for a wide range of desktop setups. Its compatibility with 8.9 cm to 6.4 cm form factors accommodates various storage devices, enhancing the flexibility of your system's storage options.
  • Durable construction
    Crafted from high-quality plastic, the BRACKET125PT stands up to the rigors of regular use. This durability, combined with compliance to RoHS and WEEE standards, ensures a reliable solution for your storage needs while also adhering to environmental regulations.
StarTech.com 2.5" HDD / SDD Mounting Bracket for 3.5" Drive Bay - Tool-less Installation - 2.5 Inch SSD HDD Adapter Bracket (BRACKET125PT) - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Plastic
10.2 cm x 15 cm x 1.3 cm
35 g
P/N: M2E4SFF8643, PEX4SFF8643, U2M2E125
Storage bay adapter
3.5" to 2.5"
Product Material
Plastic
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
6 plastic pegs
RoHS, WEEE
10.2 cm
15 cm
1.3 cm
35 g
CHMZ StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.60
CHMZ StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.26
CHMZ StarTech.com 12in Latching SATA Cable In Stock £5.50
CHMZ StarTech.com 18in Latching SATA Cable In Stock £4.40
CHMZ StarTech.com 24in Latching SATA Cable In Stock £6.08
CHMZ StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.84
CHMZ StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.64
CHMZ StarTech.com 6in Latching SATA Cable In Stock £5.08
CHMZ StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £30.84
CHMZ StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.36
CHMZ StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.33
CHMZ StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £19.99
CHMZ StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.20
CHMZ StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.80
CHMZ StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £35.55
CHMZ StarTech.com M.2 NGFF to SATA Adapter In Stock £21.11
CHMZ StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.62
CHMZ StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.64
CHMZ StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.64
CHMZ StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay In Stock £16.62
