StarTech.com 2.5" SATA HDD Enclosure - UASP
Quicklinx: 9C51WS00 Mfr#: S2510BMU33CB
  • Windows 8 (32/64 bits)
Turn a 2.5in SATA HDD/SSD into a complete external storage solution over USB 3.0 with UASP. The S2510BMU33CB UASP-enabled USB 3.0 SATA hard drive enclosure lets you connect a 2.5" SATA hard drive (HDD) or solid state drive (SSD) to your computer through an available USB port.
To maximize portability, the enclosure features a built-in USB 3.0 cable, and requires no external power adapter ensuring minimal external accessories. The cable tucks safely and discreetly away while the device is not in operation, to prevent damage or tangles.
To better utilize the full potential of your SATA III SSD/HDD the enclosure supports UASP, which allows for transfer speeds up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The USB 3.0 enclosure features a sleek design with high-quality aluminum construction and ventilation, for excellent heat dissipation.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com 2.5" USB 3.0 SATA HDD Enclosure w/ UASP and Built-in Cable - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Power Source
USB bus
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
8.4 cm x 14.5 cm x 1.3 cm
200 g
P/N: DK30BACDD, DK30CHDDPPD, DK30CHDPPDUE, HB30A3A1CFB, HB30A3A1CST, USB3DOCKHDPC, USB3SDOCKDD, USBDUP15, USBDUPE115, USBDUPE17
2.5"
Host Bus
USB 3.0
Storage Controller
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
1
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 10 pin Micro-USB Type B
1 x USB cable - integrated
USB powered, LED indicator
RoHS
Power Source
USB bus
8.4 cm
14.5 cm
1.3 cm
200 g
5 °C
10 - 90%
9C51 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
9C51 StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
9C51 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
