Hot swap drives in the front bay of your computer or server, and safeguard your data with anti-vibration protection. Increase the storage capabilities of your server or PC while protecting your data, with this 2.5" SATA drive hot-swap bay.
Turn the 3.5" front bay on your desktop computer or server into a hot-swap bay for 2.5" SATA SSD/HDD drives. Ideal for IT professionals, such as system administrators or computer operators, this mobile rack lets you quickly swap, replace, remove, or transport a drive between systems or locations. It saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers.
The 2.5" SATA drive hot-swap bay provides a protective backplane with a durable aluminum housing that offers ventilation to ensure proper air flow and heat dissipation. It features four anti-vibration bumpers, to protect your drive against vibration damage. To safeguard your data, you can lock the drive bay door to prevent unauthorized access to your drive
To maximize the speed and performance of your drives, the mobile rack supports SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
- StarTech.com 2.5 SATA Drive Hot Swap Bay - for 3.5" Front Bay - Anti-Vibration - Front Mount Design - Hard Drive Caddy - Hard Drive Rack (SATBP125VP) - storage bay adapter
- Storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x hot-swap - 2.5"
- Compatible Bay
- 1 3.5"
- Key lock, vibration protection
- Product Material
- Plastic, aluminium
- 10.16 cm x 13.5 cm x 2.5 cm
- 304 g
- 2-year warranty
- 3.5" to 2.5"
- Hard Drive Maximum Height
- 15 mm
- Product Material
- Black
Storage Controller
- Processor
- No CPU
- Bays
- 1 x SAS - 29 pin internal SAS (SFF-8482)
- Connections
- 1 x SATA 6Gb/s - 22 pin Serial ATA
- Compatible Bay
- 1 x drive cage 3.5"
- Included Accessories
- 2 security keys, screws
- Cables Included
- 1 x Serial ATA cable
- LED indicator, ventilation holes
- Limited warranty - 2 years
- 10.16 cm
- 13.5 cm
- 2.5 cm
- 304 g
- -40 °C
- 85 °C
- 5 - 65%
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.39 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.92 |
StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot | In Stock | £25.87 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.38 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.28 |
StarTech.com Mobile Rack Backplane | In Stock | £22.46 |
StarTech.com 4-Bay Backplane for SSD/HDD | In Stock | £79.84 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.38 |
