StarTech.com 2.5" Hot Swap Hard Drive Tray
Quicklinx: BM01WS00 Mfr#: SATSASTRX25
£7.46 ex VAT
£8.95 inc VAT
Exchange drives with ease with this extra drive tray for SATSASBP425 and SATSASBP125 series backplanes. This 2.5" hard drive tray lets you add even more flexibility to how you manage your data storage with the SATSASBP425 and SATSASBP125 series backplanes.
This spare drive tray can help you save time in a fast-paced work environment. It's interchangeable with trays from the StarTech.com SATSASBP125" text="single-bay backplane (SATSASBP125) and the SATSASBP425" text="four-bay backplane (SATSASBP425), giving you an extra tray in addition to the trays you're already using, to create expandable storage or as part of a rotating back-up solution.
The drive tray supports both SAS and SATA 2.5" drives, ranging from 5 to 15mm in height. To maximize the performance of your hard drives, the single and quad-bay backplanes support SAS II and SATA III enabling file transfer speeds up to 6 Gbps when paired with a compatible controller.
The durable aluminum drive tray is designed for long-lasting performance. The venting helps to ensure proper air flow and maximize heat dissipation, to help keep your drives running at optimal temperatures.
StarTech.com 2.5" Hot Swap Hard Drive Tray - Extra SSD/HDD Drive Tray for One-Bay and Four-Bay Backplanes (SATSASBP125 / SATSASBP425) - storage drive carrier (caddy)
Storage drive carrier (caddy)
Black & silver
Expansion Bays
1 x front accessible - 2.5"
Compatible Bay
1 2.5"
Hard Drive Form Factor Compatibility
2.5"
Product Material
Plastic, steel
7 cm x 11.72 cm x 1.8 cm
90 g
StarTech.com 4-Bay Backplane for U.2 Drives, Fits in a 5.25inch Bay, Quad-Bay Mobile Rack Enclosure for 2.5inch U.2 (SFF-8639) HDD/SSDs, Includes Mini-SAS HD Cables and Removeable Trays - Backplane with Fans (4U2525-SAS-BACKPLANE)
2.5"
Hard Drive Maximum Height
15 mm
Product Material
Plastic, steel
Black & silver
Storage Controller
No CPU
Bays
1 x SATA 6Gb/s / SAS 6Gb/s
Compatible Bay
1 x hot-swap 2.5"
Key, screws
FCC, RoHS, UL 94 V-0
7 cm
11.72 cm
1.8 cm
90 g
55 °C
5 - 65%
BM01 StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £26.17
BM01 StarTech.com 4-Bay Backplane for SSD/HDD In Stock £79.56
Type: Storage drive carrier (caddy)
HD Size: 2.5
