StarTech.com 1x eSATA + 1x SATA 6 Gbps PCI Express SATA Controller Card Adapter
Quicklinx: 76PQWS00 Mfr#: PEXSAT31E1
The PEXSAT31E1 2-Port PCI Express SATA/eSATA 6 Gbps (SATA 3.0) Controller Card adds one internal SATA 3.0 (6 Gbps) and one external eSATA 3.0 (6 Gbps) port, through a single PCIe slot.
Providing simple connectivity between a host computer and SATA 3.0 internal and external devices, the PCIe SATA/eSATA 3.0 adapter/controller card offers a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives, Solid State Drives (SSD), and external storage arrays, which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
Suitable for installation in slimline or small form factor computer cases, the PEXSAT31E1 offers a dual profile solution, including a low profile bracket for easy installation.
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card - storage controller (RAID) - SATA 6Gb/s / eSATA 6Gb/s - PCIe 2.0 x1
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x1
Red
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7
1.8 cm x 6.7 cm x 5.3 cm
35 g
P/N: S251SMU33EP, S3520BU33ER, S355BU33ERM, ST521PMINT
Host Bus
PCIe 2.0 x1
Red
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
2
RAID Level
Marvell 88SE9128
1 x eSATA 6Gb/s - eSATA (external) , 1 x SATA 6Gb/s - SATA (internal)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
1.8 cm
6.7 cm
5.3 cm
35 g
5 °C
50 °C
15 - 90%
