StarTech.com 1U Wall Mount Vertical Rack
Quicklinx: H140WS00 Mfr#: RK119WALLV2
This 1U 19 in server room rack enables vertical mounting of rack-mounted equipment of any depth. Mount the bracket to a wood stud wall and position equipment vertically, maximizing space utilization and optimizing layout design. The open-frame design allows for unrestricted airflow to the mounted equipment, improving cooling.
  • Versatile Design
    Mount the bracket into a wall featuring wood stud construction, where studs are spaced 16in (40.6cm) apart. The patch panel wall mount rack is perfect for SoHo (small office, home office) and other small footprint applications allowing you to vertically mount up to 130lb (58.9kg) of standard rack equipment into this 14-gauge steel bracket. The mounting holes are positioned 16in (40.6cm) apart, matching the standard for construction framework.
  • Included Hardware
    The vertical wall mount network rack conveniently includes wood screws, M5 square cage nuts, and M5 screws to attach the rack to a wall and mount your equipment. The wall mount vertical rack is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 1U 19" Wall Mount Vertical Rack, Patch Panel Wall Mount Bracket for Data/AV/IT/Computer Equipment, 1U Rack for Cabinet or Server Room, Supports 130lb (59kg) - Mounting Hardware Included (RK119WALLV2) - patch panel bracket (vertical) - 1U
Patch panel bracket (vertical)
Placing / Mounting
Wall mountable
Package Content
4 M5 cage nuts, 4 M5 screws, 6 wood screws
Rack Size
19"
Height (Rack Units)
1U
Product Material
14 gauge steel
50.5 cm x 15.5 cm x 6 cm
1.2 kg
Square hole, fixed, open frame, L-shaped mounting rail profile, 2-post
Placing / Mounting
Wall mountable
Product Material
14 gauge steel
Package Content
Rack Size
19"
Height (Rack Units)
1U
50.5 cm
15.5 cm
6 cm
1.2 kg
53.2 cm x 17 cm x 8.3 cm
Finish
Powder coat
Weight Limit
59 kg
EIA-310-E, REACH, ECA-310-E, ISTA 6
TAA Compliant
Limited warranty: - lifetime , Technical support: assistance - lifetime
H140 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.75
