StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm)
Quicklinx: 93HQWS00 Mfr#: CMHOOK1UN
Product Type: Cable management ring
Hurry, only 2 left in stock!
£4.18 ex VAT
£5.01 inc VAT
Add a cable management hook to your server rack or cabinet for strain relief and organization. The CMHOOK1UN Vertical Cable Management D-ring lets you add a 1U metal cable hook to your server rack or cabinet to provide an organized channel for your cables.
Constructed of high-quality steel, the cable D-ring measures 1.8 x 3.9in (4.5 x 10cm) and offers a flexible opening for easy insertion of bundled cables. Providing strain relief for attached cables, multiple cable rings can be attached to your rack where you need them for a versatile cable management solution.
Please see other cable management D-ring products for different size configurations: 1U Cable Management D-ring - 2.2 x 5.9in (5.7 x 15cm) - CMHOOK1UL; 1U Cable Management D-ring - 2.2 x 3.9in (5.7 x 10cm) - CMHOOK1U.
  • Functional Design
    The cable management ring features a vertical design that helps to minimize clutter by organizing cables neatly within a single rack unit, facilitating better airflow and easier equipment access.
  • Durable Material
    Constructed from robust steel, the cable management ring ensures stability and longevity, able to withstand harsh conditions commonly found in server rooms.
StarTech.com 1U Vertical 1.8 x 3.9in Server Rack Cable Management D-Ring Hook w/ Flexible Opening - Network Rack-Mount Cord Organizer Ring (CMHOOK1UN) - cable management ring - 1U
Height (Rack Units)
1U
Product Material
Steel
10.13 cm 5.7 cm
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1224WALHM, RK1232WALHM, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2433BKM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2
Product Material
Steel
Height (Rack Units)
1U
10.13 cm
5.7 cm
RoHS
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
93HQ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
93HQ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.18
93HQ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
93HQ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
93HQ StarTech.com 19in Cable Management Panel In Stock £24.18
