Quicklinx: GTBWWS00 Mfr#: SHELF-1U-20-FIXED-V
Hurry, only 1 left in stock!
£56.28 ex VAT
£67.53 inc VAT
1U Vented Server Rack Cabinet Shelf, 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf (SHELF-1U-20-FIXED-V).
  • Sturdy Construction
    The rack shelf is made of SPCC cold rolled steel which ensures durability and longevity even under heavy loads.
  • Vented Design
    The vented features of the shelf allow for enhanced airflow, helping to keep your equipment cool and functioning efficiently.
  • Easy Installation
    It comes with all necessary mounting hardware, including cage nuts and screws, facilitating a straightforward installation process.
  • Compliance with Standards
    This product meets EIA-310-E and ECA-310-E standards, ensuring compatibility with a range of rack and server equipment.
  • Ample Space
    With inner dimensions of 43.6 cm in width and 50.8 cm in depth, it provides sufficient space for various AV and network devices.
StarTech.com 1U Vented Server Rack Cabinet Shelf, 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf - rack shelf - 1U
Rack shelf
Package Content
4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
1U
Product Material
48.3 cm x 50.8 cm x 4.3 cm
3.5 kg
Vented
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
50.8 cm
4.3 cm
3.5 kg
56 cm x 55 cm x 12 cm / 4.7 kg
Inner Dimensions
43.6 cm x 50.8 cm
Weight Limit
25 kg
Vented
EIA-310-E, ECA-310-E
Limited warranty: - lifetime
GTBW StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
GTBW StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
GTBW StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
GTBW StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
GTBW StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
GTBW StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
GTBW StarTech.com 1U Vented Shelf 12in In Stock £34.44
GTBW StarTech.com 2U Vented Shelf 14in In Stock £62.75
GTBW StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £58.55
