Improve the organization and appearance of your rack in seconds, with a tool-less vented blanking panel. This vented 1U rack panel can mount onto any standard 19-inch 2 or 4-post server rack, to blank out unused rack space. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
The panel features a vented design that enables unobstructed airflow through your rack, to help ensure your equipment is running at an optimal temperature.
For fast and easy installation, this blanking panel features a tool-less design that latches onto a standard 19 in. server rack, saving you time and hassle.
Professional look
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room. -
Maximize airflow
The panel features a vented design that enables unobstructed airflow through your rack, to help ensure your equipment is running at an optimal temperature. -
Tool-less installation
For fast and easy installation, this blanking panel features a tool-less design that latches onto a standard server rack, saving you time and hassle.
- StarTech.com 1U Blanking Panel - 19in Vented Server Rack Panel - Tool-less Installation - TAA Compliant Filler Panel (RKPNLTL1UV) - rack blanking panel - 1U
- Product Type
- Rack blanking panel
- Height (Rack Units)
- 1U
- Product Material
- Plastic, steel
- 48.2 cm x 2.2 cm x 4.4 cm
- 199 g
- Vented
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK619WALL, RK619WALLGB, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Product Material
- Plastic, steel
- 1U
- 48.2 cm
- 2.2 cm
- 4.4 cm
- 199 g
- Vented
- RoHS
- Limited warranty: - 2 years
- Designed For
StarTech.com 4U Vented Panel with Hinge | In Stock | £28.33 |
