The durable rack mount tray can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your 19-inch rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room, data center or any other location with limited space available.
You can install the 1U network cabinet shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable such as a computer, or for storing your tools.
Ensure your equipment is secure
The durable rack mount tray can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel. -
Make the most of your available space
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your 19-inch rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room, data center or any other location with limited space available. -
Customize your setup
You can install the 1U network cabinet shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable such as a computer, or for storing your tools. -
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The CABSHELF116 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 1U Server Rack Cabinet Shelf, 16in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 44lbs Weight Capacity - 1U Rack Shelf 16" Deep (CABSHELF116) - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- Pack lower case, 4 M6 cage nuts, 4 M6-12 screws
- Black
- Rack Size
- 16"
- Height (Rack Units)
- 1U
- Product Material
- Steel
- 44.1 cm x 40.1 cm x 4.3 cm
- 3.26 kg
- Cantilever
- Limited lifetime warranty
- Designed For
- P/N: CABSHELF116V, RK1536BKF, RK1833BKM, RK1836BKF
- Product Type
- Rack shelf
- Product Material
- Steel
- Package Content
- Rack Size
- 16"
- 1U
- 44.1 cm
- 40.1 cm
- 4.3 cm
- 3.26 kg
- Shipping Dimensions (WxDxH) / Weight
- 54.5 cm x 44 cm x 7.5 cm / 3.9 kg
- Black
- Weight Limit
- 20 kg
- Mounting Kit
- Included
- Cantilever
- EIA-310-E, RoHS, REACH, ECA-310-E
- Limited warranty: - lifetime
- Designed For
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.70 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £32.84 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.84 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £32.35 |
StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable | In Stock | £19.78 |
