The durable rack mount tray can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your 19-inch rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room, data center or any other location with limited space available.
You can install the 1U network cabinet shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable such as a computer, or for storing your tools.
- StarTech.com 1U Server Rack Cabinet Shelf, 16in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 44lbs Weight Capacity - 1U Rack Shelf 16" Deep (CABSHELF116) - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- Pack lower case, 4 M6 cage nuts, 4 M6-12 screws
- Black
- Rack Size
- 16"
- Height (Rack Units)
- 1U
- Product Material
- Steel
- 44.1 cm x 40.1 cm x 4.3 cm
- 3.26 kg
- Cantilever
- Limited lifetime warranty
- Designed For
- P/N: CABSHELF116V, RK1536BKF, RK1833BKM, RK1836BKF
- Product Type
- Rack shelf
- Product Material
- Steel
- Package Content
- Rack Size
- 16"
- 1U
- 44.1 cm
- 40.1 cm
- 4.3 cm
- 3.26 kg
- Shipping Dimensions (WxDxH) / Weight
- 54.5 cm x 44 cm x 7.5 cm / 3.9 kg
- Black
- Weight Limit
- 20 kg
- Mounting Kit
- Included
- Cantilever
- EIA-310-E, RoHS, REACH, ECA-310-E
- Limited warranty: - lifetime
- Designed For
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.28 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.54 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £35.80 |
StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable | In Stock | £22.61 |
