StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant
Quicklinx: FLXBWS00 Mfr#: CABSHELF116
£39.75 ex VAT
£47.70 inc VAT
The durable rack mount tray can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your 19-inch rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room, data center or any other location with limited space available.
You can install the 1U network cabinet shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable such as a computer, or for storing your tools.
  • Ensure your equipment is secure
  • Make the most of your available space
  • Customize your setup
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The CABSHELF116 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 1U Server Rack Cabinet Shelf, 16in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 44lbs Weight Capacity - 1U Rack Shelf 16" Deep (CABSHELF116) - rack shelf - 1U
Rack shelf
Package Content
Pack lower case, 4 M6 cage nuts, 4 M6-12 screws
Rack Size
16"
Height (Rack Units)
1U
Product Material
Steel
44.1 cm x 40.1 cm x 4.3 cm
3.26 kg
Cantilever
P/N: CABSHELF116V, RK1536BKF, RK1833BKM, RK1836BKF
Rack shelf
Product Material
Steel
Package Content
Rack Size
16"
Height (Rack Units)
1U
44.1 cm
40.1 cm
4.3 cm
3.26 kg
54.5 cm x 44 cm x 7.5 cm / 3.9 kg
Weight Limit
20 kg
Mounting Kit
Included
Cantilever
EIA-310-E, RoHS, REACH, ECA-310-E
Limited warranty: - lifetime
FLXB StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
FLXB StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
FLXB StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
FLXB StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
FLXB StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
FLXB StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable In Stock £17.95
