Quicklinx: BHCRWS00 Mfr#: RKPNLTL1U
Product Type: Blank panel
Select:
Hurry, only 1 left in stock!
£12.99 ex VAT
£15.58 inc VAT
Improve the organization and appearance of your rack in seconds, with a tool-less solid blanking panel. You can improve the appearance and airflow of any standard 19-inch server rack in seconds, using this 1U blanking panel.
The blanking panel creates a clean and professional look by covering empty space and visible cables, for a more organized server room.
For fast and easy installation, this blanking panel features a tool-less design that latches onto a standard 19 in. server rack, saving you time and hassle.
The blanking panel features a solid design that helps guide airflow down the back of your rack, rather than passing through unused spaces. Improved airflow helps ensure your rack-mounted equipment is running at an optimal temperature.
  • Professional look
  • Tool-less installation
  • Improve airflow
StarTech.com Blanking Panel - 1U - 19in - Tool-less - Steel - Black - TAA Compliant - Blank Rack Panel - Filler Panel (RKPNLTL1U) - blank panel - 1U
Blank panel
Location
Front
Rack Size
19"
Height (Rack Units)
1U
Product Material
Plastic, steel
49 cm x 5.5 cm x 3.2 cm
320 g
P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK619WALL, RK619WALLGB, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Blank panel
Location
Front
Product Material
Plastic, steel
Rack Size
19"
Height (Rack Units)
1U
49 cm
5.5 cm
3.2 cm
320 g
EIA-310-D, RoHS
Limited warranty: - 2 years
