Mount a 1U SV431 Series KVM switch into your server rack or cabinet. The SV431RACK 1U rack mount brackets let you mount your SV431 / SV431D KVM switch into a rack or cabinet.
Designed for simple installation and maximum server rack space-efficiency, the rack brackets include a cable support bracket that reduces stress on KVM cables and switch connectors.
Sturdy Design
Constructed with durable materials to withstand the rigors of server environments, ensuring long-lasting support for your equipment. -
Easy Installation
Setup is straightforward, allowing users to quickly mount their KVM switch with minimal effort, saving time during deployment.
- StarTech.com Rackmount Brackets - 1U Rack Mount - KVM Switch Brackets - SV431 Series - Rack Mount Rails (SV431RACK) - rack bracket kit - 1U
- Product Type
- Rack bracket kit
- Height (Rack Units)
- 1U
- Limited lifetime warranty
- Designed For
- P/N: ST124HDMI2, SV231DPU34K, SV431, SV431DHD4KU, SV431DPDDUA2, SV431DPU3A2, SV431DPUA2, SV431DUSB, SV431DUSBU, SV431DVGAU2A, SV431DVIUA, SV431DVIUAGB, SV431DVIUAHR, SV431H, SV431HDU3A2, SV431TDVIUA, SV431USB, SV431USBAE, SV431USBAEGB, SV565FXDUSA
- Product Type
- Rack bracket kit
- 1U
- Rack Mounting Kit
- Included
- Limited warranty - lifetime
- Designed For
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £87.61 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £245.84 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £256.34 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £253.13 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £150.51 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £360.98 |
StarTech.com 4 Port HDMI KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £322.22 |
