Mount a 1U SV431 Series KVM switch into your server rack or cabinet. The SV431RACK 1U rack mount brackets let you mount your SV431 / SV431D KVM switch into a rack or cabinet.
Designed for simple installation and maximum server rack space-efficiency, the rack brackets include a cable support bracket that reduces stress on KVM cables and switch connectors.
- StarTech.com Rackmount Brackets - 1U Rack Mount - KVM Switch Brackets - SV431 Series - Rack Mount Rails (SV431RACK) - rack bracket kit - 1U
- Product Type
- Rack bracket kit
- Height (Rack Units)
- 1U
- Limited lifetime warranty
- Designed For
- P/N: ST124HDMI2, SV231DPU34K, SV431, SV431DHD4KU, SV431DPDDUA2, SV431DPU3A2, SV431DPUA2, SV431DUSB, SV431DUSBU, SV431DVGAU2A, SV431DVIUA, SV431DVIUAGB, SV431DVIUAHR, SV431H, SV431HDU3A2, SV431TDVIUA, SV431USB, SV431USBAE, SV431USBAEGB, SV565FXDUSA
- Product Type
- Rack bracket kit
- 1U
- Rack Mounting Kit
- Included
- Limited warranty - lifetime
- Designed For
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.48 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £277.79 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £277.28 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £164.86 |
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £308.73 |
StarTech.com 4-port Dual VGA KVM Switch | In Stock | £176.91 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £395.01 |
StarTech.com 4 Port HDMI KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £352.60 |
