StarTech.com 1U Rack-Mount Cable Lacing Bar
Quicklinx: HHY0WS00 Mfr#: 12S-CABLE-LACING-BAR
27 In Stock
£11.81 ex VAT
£14.17 inc VAT
CABLE MANAGER BAR: Organize network/power cables in a 19" server rack with this heavy-duty 1U bar; Eliminate sharp bends at connector ends and reduce port tension.
ADJUSTABLE DEPTH: Horizontal cable lacing crossbar allows you to vary the depth of the horizontal bar in relation to the rack mounting posts; adjustable depth from 40 to 96 mm; fixed 96 mm side support depth.
DOUBLE INSTALLATION: lacing bar can be installed inwards/outwards of the rack uprights for optimum routing, reduced space requirements and better air circulation; M6 cage nuts/screws included.
FLEXIBLE INSTALLATION: Mounting bar has mounting points spaced 8.5mm apart along the length of the bar; To keep cables attached to the bar, consider HKLP100 hook-and-loop fasteners and CBMZT6BK cable ties (sold separately).
HEAVY-DUTY CONSTRUCTION: SPCC steel construction enables the cable support bar to withstand the load of all types of cables/cable harnesses; For use with patch panels/servers/switches/NAS/PDU/KVM and more.
  • Efficient organization
    The 1U Rack Mountable Cable Lacing Bar with Adjustable Depth offers a structured way to manage cables in 19" racks and cabinets, ensuring a tidy and accessible setup for patch panels, switches, and PDUs.
  • Versatile design
    Featuring adjustable depth and a reversible configuration, this cable support guide accommodates various cable lengths and orientations, making it a flexible solution for different rack setups.
  • Durable construction
    Constructed from 2 mm SPCC steel and finished with a powder coat, this horizontal cable guide is built to last, providing reliable cable support in any server room or data center environment.
StarTech.com 1U Rack Mountable Cable Lacing Bar w/Adjustable Depth, Cable Support Guide For Organized 19" Racks/Cabinets, Horizontal Cable Guide For Patch Panels/Switches/PDUs - rack cable management lacing bar (horizontal) - 1U
Rack cable management lacing bar (horizontal)
Package Content
4 M6 cage nuts, 4 M4 screws, 4 M6 screws, 4 M6 plastic washers
Rack Size
19"
Height (Rack Units)
1U
Product Material
2 mm SPCC steel
48.3 cm x 9.6 cm x 4.4 cm
500 g
Adjustable depth, reversible
Product Material
2 mm SPCC steel
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
9.6 cm
4.4 cm
Adjustable Height
4-9.6 cm
500 g
600 g
Finish
Powder coat
EIA-310-E, ECA-310-E
Limited warranty: - 2 years
HHY0 StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small In Stock £6.64
HHY0 StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Medium In Stock £7.48
HHY0 StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large In Stock £8.29
HHY0 StarTech.com 100 Pack 4" White Cable Ties In Stock £4.64
Product Type: Rack cable management lacing bar
