CABLE MANAGER BAR: Organize network/power cables in a 19" server rack with this heavy-duty 1U bar; Eliminate sharp bends at connector ends and reduce port tension.
ADJUSTABLE DEPTH: Horizontal cable lacing crossbar allows you to vary the depth of the horizontal bar in relation to the rack mounting posts; adjustable depth from 40 to 96 mm; fixed 96 mm side support depth.
DOUBLE INSTALLATION: lacing bar can be installed inwards/outwards of the rack uprights for optimum routing, reduced space requirements and better air circulation; M6 cage nuts/screws included.
FLEXIBLE INSTALLATION: Mounting bar has mounting points spaced 8.5mm apart along the length of the bar; To keep cables attached to the bar, consider HKLP100 hook-and-loop fasteners and CBMZT6BK cable ties (sold separately).
HEAVY-DUTY CONSTRUCTION: SPCC steel construction enables the cable support bar to withstand the load of all types of cables/cable harnesses; For use with patch panels/servers/switches/NAS/PDU/KVM and more.
Efficient organization
The 1U Rack Mountable Cable Lacing Bar with Adjustable Depth offers a structured way to manage cables in 19" racks and cabinets, ensuring a tidy and accessible setup for patch panels, switches, and PDUs. -
Versatile design
Featuring adjustable depth and a reversible configuration, this cable support guide accommodates various cable lengths and orientations, making it a flexible solution for different rack setups. -
Durable construction
Constructed from 2 mm SPCC steel and finished with a powder coat, this horizontal cable guide is built to last, providing reliable cable support in any server room or data center environment.
- StarTech.com 1U Rack Mountable Cable Lacing Bar w/Adjustable Depth, Cable Support Guide For Organized 19" Racks/Cabinets, Horizontal Cable Guide For Patch Panels/Switches/PDUs - rack cable management lacing bar (horizontal) - 1U
- Product Type
- Rack cable management lacing bar (horizontal)
- Package Content
- 4 M6 cage nuts, 4 M4 screws, 4 M6 screws, 4 M6 plastic washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- 2 mm SPCC steel
- 48.3 cm x 9.6 cm x 4.4 cm
- 500 g
- Adjustable depth, reversible
- 2-year warranty
- Product Type
- Product Material
- 2 mm SPCC steel
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 9.6 cm
- 4.4 cm
- Adjustable Height
- 4-9.6 cm
- 500 g
- Shipping Dimensions (WxDxH) / Weight
- 600 g
- Black
- Finish
- Powder coat
- EIA-310-E, ECA-310-E
- Limited warranty: - 2 years
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small | In Stock | £7.67 |
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Medium | In Stock | £8.72 |
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large | In Stock | £9.57 |
StarTech.com 100 Pack 4" White Cable Ties | In Stock | £4.83 |
