StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover
Quicklinx: 9PRBWS00 Mfr#: CMDUCT1UX
Select:
10 In Stock
£17.75 ex VAT
£21.30 inc VAT
Organize cables in your server rack or cabinet with a horizontal, covered cable duct. The CMDUCT1UX 1U Finger Duct Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize horizontal cabling, through a covered cable duct. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The cable organizer features a removable top cover that makes it easy to add or remove bundled cables quickly. The duct also offers a series of fingers on either side, as well as pass-through holes at the back to help you route your cables where you need them, and reduce cable strain in the process.
Made of high-quality steel, the cable manager is a durable solution for your server room or wiring closet. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (M5 and M6).
  • Effective organization
    This rack cable management panel helps manage and organize cables, keeping them tidy and easily accessible.
  • Space-saving design
    With a height of 1U, this panel optimizes rack space, allowing for maximum utilization of the available area.
  • Easy installation
    The included mounting kit allows for installation in compatible server racks, making setup quick and straightforward.
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover - Server Rack Cable Duct - Rack Cable Organizer / Manager (CMDUCT1UX) - rack cable management panel - 1U
Rack cable management panel
Rack Size
19"
Height (Rack Units)
1U
48.2 cm x 6.12 cm x 4.7 cm
680 g
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK1536BKF, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1836BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2
Rack Size
19"
Height (Rack Units)
1U
48.2 cm
6.12 cm
4.7 cm
680 g
Mounting Kit
Included
RoHS
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK1536BKF, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK1836BKF, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
9PRB StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
9PRB StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
9PRB StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
9PRB StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
Product Type: Rack cable management panel
