Control your server or KVM switch from a centralized HD KVM console. Providing centralized control of your single PC or dozens of servers, this HD rackmount KVM console also gives you easy access to and visibility of your system while it's mounted in a server rack or cabinet. Connected to your servers through a separate KVM switch (sold separately), the LCD console installs into 1U of rack-space, offering a space-efficient solution for complete console control.
The 1080p KVM console's monitor is 17.3" and LED back-lit, for low power consumption. It supports high-definition resolutions up to 1920x1080 providing sharper video performance. This HD console also provides more screen space, helping you to run multiple applications on the same screen, increasing your productivity.
The rack-mount LCD console slides out from 1U of rack space, enabling you to easily monitor and control a single server or multiple servers when connected through a KVM switch. The rackmount VGA KVM features a handle that makes it easy to slide the console in and out of the server rack, keeping your area organized and clutter-free.
This single-port KVM console comes with everything you need to set up: 1 Audio Cable; 1 Set of KVM Cables (VGA); 2 Rear Mounting Brackets; M5 Cage Nuts and Screws.
This KVM console provides all the essential controls you'll need to manage your server room at a low cost. The console features a built-in keyboard and a touchpad for intuitive control, as well as a high-definition LCD display.
StarTech.com offers a wide selection of KVM consoles to help you access your systems more efficiently without the expense and clutter of extra peripherals.
- StarTech.com Rackmount KVM Console HD 1080p, Single Port VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured 1U LCD KVM Drawer with Cables & Hardware, USB Support, 50,000 MTBF - 17in. LCD KVM Console (RKCONS17HD) - KVM console - Full HD (1080p) - 17.3"
- KVM console - 17.3"
- KVM Switch
- USB - 1 ports
- Keyboard, touchpad
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.1989 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- 262,144 colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- 48.3 cm x 56.5 cm x 4.3 cm
- Height (Rack Units)
- 1U
- 13.7 kg
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- UL, FCC, RoHS, PSE Mark
- 2-year warranty
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17.3"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1989 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- 262,144 colours
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 170
- Black
- 1U
- 13.7 kg
Input
KVM
- KVM switch - 1 ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1080p @ 60 Hz
- VGA
- LED indicator
- Included Accessories
- 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
- Cables Included
- 1 x keyboard / mouse / video cable - 1.8 m
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 13 Watt
- Shipping Weight
- 16 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £532.60 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £325.52 |
StarTech.com 16 port KVM VGA Console with KVM Switch - 19" | In Stock | £1,263.12 |
StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor | In Stock | £1,071.04 |
StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor | In Stock | £1,193.28 |
StarTech.com 1U HD Single Server KVM | In Stock | £912.60 |
StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles | In Stock | £49.13 |
StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles | In Stock | £21.03 |
