Server Rack Cable Management - 1U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT1UX2).
Efficient organization
The Server Rack Cable Management panel is designed to offer a neat and efficient solution for organizing cables in a server rack. Its horizontal 1U design fits perfectly in standard 19" racks, ensuring a tidy appearance and improved airflow, which is crucial for maintaining optimal equipment performance. -
Durable construction
Crafted from high-quality steel, this cable management panel is built to last. The robust material ensures it can withstand the rigors of a busy server room environment, providing reliable support for your cabling needs. -
Easy installation
With front mountable design and included mounting hardware such as M6 x 15 screws, M6 cage nuts, M6 plastic washers, and M6 x 12 mm screws, the installation process is straightforward. This design simplifies the task of adding or removing cables, making it an ideal choice for dynamic server environments.
- StarTech.com Server Rack Cable Management - 1U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT1UX2) - rack cable management panel (horizontal) - 1U
- Product Type
- Rack cable management panel (horizontal)
- Placing / Mounting
- Front mountable
- Package Content
- 4 M6 cage nuts, cable duct, 2 M6 x 15 screws, 4 M6 x 12mm screws, 4 M6 plastic washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- High quality steel
- 48.3 cm x 7.2 cm x 4.4 cm
- Pass-through holes
- 2-year warranty
- Product Type
- Front mountable
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 7.2 cm
- 4.4 cm
- Shipping Dimensions (WxDxH) / Weight
- 54.5 cm x 10.5 cm x 14.5 cm / 1.2 kg
- Black
- RoHS, ANSI/EIA-RS-310-D
- Limited warranty: - 2 years , Technical support: assistance - lifetime
