StarTech.com 1U Covered Cable Finger Duct
Quicklinx: H1T3WS00 Mfr#: CMDUCT1UX2
Server Rack Cable Management - 1U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT1UX2).
  • Efficient organization
    The Server Rack Cable Management panel is designed to offer a neat and efficient solution for organizing cables in a server rack. Its horizontal 1U design fits perfectly in standard 19" racks, ensuring a tidy appearance and improved airflow, which is crucial for maintaining optimal equipment performance.
  • Durable construction
    Crafted from high-quality steel, this cable management panel is built to last. The robust material ensures it can withstand the rigors of a busy server room environment, providing reliable support for your cabling needs.
  • Easy installation
    With front mountable design and included mounting hardware such as M6 x 15 screws, M6 cage nuts, M6 plastic washers, and M6 x 12 mm screws, the installation process is straightforward. This design simplifies the task of adding or removing cables, making it an ideal choice for dynamic server environments.
StarTech.com Server Rack Cable Management - 1U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT1UX2) - rack cable management panel (horizontal) - 1U
Rack cable management panel (horizontal)
Placing / Mounting
Front mountable
Package Content
4 M6 cage nuts, cable duct, 2 M6 x 15 screws, 4 M6 x 12mm screws, 4 M6 plastic washers
Rack Size
19"
Height (Rack Units)
1U
Product Material
High quality steel
48.3 cm x 7.2 cm x 4.4 cm
Pass-through holes
Placing / Mounting
Front mountable
Product Material
High quality steel
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
7.2 cm
4.4 cm
54.5 cm x 10.5 cm x 14.5 cm / 1.2 kg
Pass-through holes
RoHS, ANSI/EIA-RS-310-D
Limited warranty: - 2 years , Technical support: assistance - lifetime
