Organize cables while keeping dust out of the rack with a brush-style cable manager. The CMBRUSH1U Brush Strip Cable Management Panel mounts to a standard 19" 2 or 4-post rack to organize cables while keeping dust and dirt out of the rack. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality steel with high-density nylon bristles, the 1U brush plate creates a clean looking point of entry and offers cable separation for simple cable organization. The brush panel also promotes proper airflow through the rack by closing off open spaces between equipment.
For easy installation, this cable organizer comes complete with 2 sets of rack screws (10/32 and 12/24).
                Durable constructionThe steel material used in this panel ensures it can withstand the rigors of a busy data center while maintaining its structure and integrity over time.
                Space-saving designWith a height of 1U, this cable management panel allows for efficient use of vertical space in a rack, helping to maximize your setup.
- StarTech.com 1U High-density Brush Strip Cable Management Panel - Sturdy Steel Horizontal Data Centre Cable Management Panel (CMBRUSH1U) - rack cable management panel - 1U
- Product Type
- Rack cable management panel
- Package Content
- 4 screws (10-32), 4 screws (12-24)
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Steel
- 48.5 cm x 2.02 cm x 4.37 cm
- 400 g
- 2-year warranty
- Designed For
- P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12V2
- Product Type
- Product Material
- Steel
- Package Content
- Rack Size
- 19"
- 1U
- 48.5 cm
- 2.02 cm
- 4.37 cm
- 400 g
- Black
- RoHS
- Limited warranty: - 2 years
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
|  | StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
|  | StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.23 |
|  | StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.20 |
|  | StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.24 |
|  | StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.31 |
|  | StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
|  | StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
