StarTech.com 1U Blanking Panels - 10 Pack
Quicklinx: D1V0WS00 Mfr#: BLANKP10
£43.08 ex VAT
£51.69 inc VAT
This 10-pack of 1U blanking panels can help you to dramatically improve the appearance and airflow of your EIA-310 compliant 19 in. server rack.
These blank rack panels create a clean and professional look by covering empty rack spaces and visible cables, for a more organized server room.
For fast and easy installation, these rack blanks feature a tool-less design that latches onto a standard 19 in. server rack, saving you time and hassle.
The filler panels feature a solid design that helps guide airflow down the back of your rack-mounted equipment, rather than through unused units of rack space. This helps expel any operating heat from your rack-mounted equipment, to keep it running at optimal temperatures.
  • Functional design
    These blanking panels are specifically designed for 1U rack space to effectively fill gaps in server racks. This ensures no open slots, aiding in airflow management and thermal performance.
  • Easy installation
    The toolless design of these rack blanking panels allows users to install them quickly. Simply push them into place without the need for tools, saving both time and effort during setup.
StarTech.com 1U Blanking Panels - Tool Less Blank Rack Panels - 10 Pack - Rack Mount Panel for 19 in. Server Rack (BLANKP10) - rack blanking panel - 1U
Rack blanking panel
Packaged Quantity
10 (specifications are for single item)
Location
Front
Rack Size
19"
Height (Rack Units)
1U
49 cm x 4.2 cm x 3.2 cm
5-year warranty
Packaged Quantity
Rack blanking panel
Location
Front
Rack Size
19"
Height (Rack Units)
1U
49 cm
4.2 cm
3.2 cm
Limited warranty: - 5 years
