StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg
Quicklinx: 6B9QWS00 Mfr#: ADJSHELF
Product Type: Rack shelf, Rack shelf
Hurry, only 2 left in stock!
£96.93 ex VAT
£116.31 inc VAT
Add a sturdy, adjustable depth shelf into almost any server rack or cabinet. The ADJSHELF Adjustable Mounting Depth Rack Mount Shelf offers a simple way to effectively organize mission critical computer hardware in your server racks and cabinets.
Compatible with all 19in (wide) server racks/cabinets, the fixed rack shelf can be adjusted from 19in to 38in (mount depth) as necessary. A sturdy cold-rolled steel construction provides long term durability and enables a weight capacity of up to 175 lbs (80 kg).
  • Versatile adjustable depth
    The adjustable depth allows for customization ranging from 19.5 to 38 inches, accommodating various equipment sizes and types.
  • Effective vented design
    The vented construction enhances airflow, ensuring effective cooling and heat management for sensitive electronic equipment.
  • Robust weight capacity
    With a weight limit of 175 lbs, this shelf provides the strength and stability needed for heavy equipment, preventing sagging or failure.
  • Compliance with RoHS standards
    This product meets RoHS compliance, ensuring it is manufactured with environmentally safe processes and materials.
  • Compatible with standard 19-inch racks
    Designed specifically for 19-inch racks, this shelf seamlessly integrates into existing setups, making installation straightforward and efficient.
StarTech.com 1U Adjustable Vented Server Rack Mount Shelf - 175lbs - 19.5 to 38in Deep Universal Tray for 19" AV/ Network Equipment Rack (ADJSHELF) - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
44.5 cm x 70 cm x 4 cm
4.4 kg
Adjustable depth, vented
1-year warranty
P/N: 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM62, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RKQMCAB12
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
44.5 cm
70 cm
4 cm
4.4 kg
Weight Limit
79.4 kg
RoHS
Limited warranty: - 1 year
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
6B9Q StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £98.46
6B9Q StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
6B9Q StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.59
6B9Q StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.49
6B9Q StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.73
6B9Q StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
6B9Q StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £64.29
6B9Q StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £79.14
6B9Q StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £84.03
6B9Q StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £161.59
