Server Rack Shelf - 1U - 330lbs(150 kg) max. capacity - 19.5 to 38in 4-Post Adjustable Mounting Depth - Heavy Duty - 27.5in Deep (ADJSHELFHDV2).
Universal 19'' fit
This server rackmount shelf is designed to fit any 19" 4-post server rack and has a fixed surface depth of 27.56", and an adjustable mounting depth range of 19.5 - 38" for your data, networking or other small-form tools or equipment. -
Compact design
The adjustable rack shelf features a very compact form factor, making it ideal for non-rackmount equipment, tools and peripherals in your home, studio or office space. -
Heavy-duty and durable design
Constructed with SPCC commercial cold-rolled steel, the sturdy cabinet shelf ensures longterm durability and supports a total weight load of 330 lbs. / 150 kg. -
Versatile functionality
With a surface depth of 27.56" and adjustable mounting depth range of 19.5 - 38", this shelf can work with any 19" cabinet or equipment rack; it provides additional storage space for your tools or accessories.
- StarTech.com Server Rack Shelf - 1U - 330lbs(150 kg) max. capacity - 19.5 to 38in 4-Post Adjustable Mounting Depth - Heavy Duty - 27.5in Deep (ADJSHELFHDV2) - rack shelf - vented, adjustable - 1U
- Product Type
- Rack shelf - vented, adjustable
- Package Content
- 2 front rack mounting brackets, 8 M6 cage nuts, 8 M6 washers, 8 M6x12 screws, 2 rear rack mounting brackets, 8 M6x12 mounting bracket screws
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 70 cm x 4.4 cm
- Heavy-duty, 4 post, front and rear mounting profile, adjustable mounting depth (495 - 974 mm)
- Limited lifetime warranty
- Product Type
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 70 cm
- 4.4 cm
- Shipping Dimensions (WxDxH) / Weight
- 77.5 cm x 53 cm x 11 cm / 6.8 kg
- Black
- Weight Limit
- 150 kg
- EIA-310-D, RoHS
- Limited warranty: - lifetime , Technical support: assistance - lifetime
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.71 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
