StarTech.com 1U Adj Rack Mount Shelf
Quicklinx: H1T1WS00 Mfr#: ADJSHELFHD2
Product Type: Rack shelf, Rack shelf
£78.36 ex VAT
£94.03 inc VAT
Server Rack Shelf - 1U - 330lbs(150 kg) max. capacity - 19.5 to 38in 4-Post Adjustable Mounting Depth - Network Cabinet Shelf - 19in Rack Mount Shelf - 27.5in Deep (ADJSHELFHD2).
  • Universal 19'' fit
    This server rackmount shelf is designed to fit any 19" 4-post server rack and has a fixed surface depth of 27.56", and an adjustable mounting depth range of 19.5 - 38" for your data, networking or other small-form tools or equipment.
  • Compact design
    The adjustable rack shelf features a very compact form factor, making it ideal for non-rackmount equipment, tools and peripherals in your home, studio or office space.
  • Heavy-duty and durable design
    Constructed with SPCC commercial cold-rolled steel, the sturdy cabinet shelf ensures longterm durability and supports a total weight load of 330 lbs. / 150 kg.
  • Versatile functionality
    With a surface depth of 27.56" and adjustable mounting depth range of 19.5 - 38", this shelf can work with any 19" cabinet or equipment rack; it provides additional storage space for your tools or accessories.
StarTech.com Server Rack Shelf - 1U - 330lbs(150 kg) max. capacity - 19.5 to 38in 4-Post Adjustable Mounting Depth - Network Cabinet Shelf - 19in Rack Mount Shelf - 27.5in Deep (ADJSHELFHD2) - rack shelf - adjustable - 1U
Rack shelf - adjustable
Package Content
2 front rack mounting brackets, 8 M6 cage nuts, 8 M6 washers, 8 M6x12 screws, 2 rear rack mounting brackets, 8 M6x12 mounting bracket screws
Rack Size
19"
Height (Rack Units)
1U
Product Material
SPCC cold rolled steel
48.3 cm x 70 cm x 4.4 cm
Heavy-duty, 4 post, front and rear mounting profile, adjustable mounting depth (495 - 974 mm)
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
70 cm
4.4 cm
77.5 cm x 53 cm x 11 cm / 7.2 kg
Weight Limit
150 kg
EIA-310-D, RoHS
Limited warranty: - lifetime , Technical support: assistance - lifetime
H1T1 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
H1T1 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.44
H1T1 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.55
H1T1 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
