StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg
Quicklinx: 7NXFWS00 Mfr#: CABSHELF1U
Product Type: Rack shelf, Rack shelf
38 In Stock
£28.54 ex VAT
£34.24 inc VAT
The CABSHELF1U 1U (Black) Universal Fixed Server Rack Cabinet Shelf lets you add a compact fixed storage shelf to any standard 19-inch server rack or cabinet with front mount options. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 15kg (33lbs) of equipment - a perfect solution for storing small form non-rackmount equipment, tools, peripherals or accessories in your rack, to keep them readily accessible.
StarTech.com 1U Server Rack Cabinet Shelf, 7in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 33lbs Weight Capacity - 1U Rack Shelf 7" Deep (CABSHELF1U) - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
Weight Limit
15 kg
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
7NXF StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
7NXF StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £100.06
7NXF StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
7NXF StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.09
7NXF StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.25
7NXF StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.28
7NXF StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
7NXF StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
7NXF StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £28.54
7NXF StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.50
7NXF StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £45.90
7NXF StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £39.69
7NXF StarTech.com Vented 1U Rack Shelf - 7in In Stock £23.86
7NXF StarTech.com 1U Rack Shelf - 10in In Stock £24.25
7NXF StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £32.16
7NXF StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.58
7NXF StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.36
7NXF StarTech.com 1U Vented Shelf 12in In Stock £34.43
7NXF StarTech.com 1U Vented Shelf 20in In Stock £55.10
7NXF StarTech.com 2U Vented Shelf 14in In Stock £61.91
7NXF StarTech.com 2U Vented Shelf 20in In Stock £73.83
7NXF StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £69.08
