Add a copper heatsink cooler for a Socket 7/370 CPU for a 1U server. This 60x10mm Socket 7/370 CPU Cooler helps keep your 1U servers running smoothly, by providing a reliable, cost-effective server cooling solution.
The server CPU cooler features a copper base and socket-type CPU fan, ensuring rapid heat dissipation in the reduced space of a 1U server environment.
The CPU cooler is powered through a simple TX3 connection to the server power supply, and is suitable for all Intel Celeron/PIII processors and AMD Athlon/Duron processors up to 1GHz.
- StarTech.com 1U 60x10mm Socket 7/370 CPU Cooler Fan - Low Profile CPU Cooler w/ Copper Heatsink & TX3 (FAN3701U) processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket A, Socket 370
- Heatsink Material
- Copper
- Fan Diameter
- 60 mm
- Fan Height
- 10 mm
- Rotation Speed
- 5000 rpm
- Air Flow
- 13.5 cfm
- Noise Level
- 31 dBA
- Power Connector
- 3-pin plug
- Ball bearing
- Product Material
- Copper
- 0.2 kg
- 1-year warranty
- Product Type
- Processor cooler
- Product Material
- Copper
- 0.2 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Heatsink Dimensions
- 64 mm x 63 mm x 10 mm
- Fan Diameter
- 60 mm
- Fan Height
- 10 mm
- Rotation Speed
- 5000 rpm
- Air Flow
- 13.5 cfm
- Noise Level
- 31 dBA
- Power Connector
- 3-pin plug
- Ball bearing
- Limited warranty - 1 year
