The RKCONS2001GB 1U 20-inch High Resolution Folding Rack Mount LCD Console (for 19-inch racks) provides total KVM control right from your server rack, with a complete keyboard, monitor, mouse, and audio control point integrated into a space-efficient 1U of rack/cabinet space.
This durable and compact KVM Rack Console offers the largest (20.1-inches) and highest resolution (up to 1600x1200) TFT-LCD monitor available in a 1U rackmount design. When not in use, it can be folded and slid back into the server rack on sturdy mounting rails (included).
With the included cables, the LCD console can be connected to virtually any multi-port KVM switch for control of multiple servers/computers, providing a scalable solution that lets you determine the type of KVM switch to use. Plus, the console supports connection to PS/2, USB, VGA and DVI systems, accommodating both legacy and cutting edge computers.
- StarTech.com High Res RackMount LCD Console for 19" Rack - LED monitor - 20.1"
- LED-backlit LCD monitor - 20.1"
- Keyboard, touchpad
- Native Resolution
- 1600 x 1200
- Pixel Pitch
- 0.255 mm
- Contrast Ratio
- 1000:1
- Response Time
- 15 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- 60.8 cm x 4.4 cm x 44.8 cm
- Height (Rack Units)
- 1U
- 15.5 kg
- Localisation
- United Kingdom
- UL, FCC, RoHS
- 2-year warranty
- Display Type
- Diagonal Size
- 20.1"
- Native Resolution
- 1600 x 1200
- Pixel Pitch
- 0.255 mm
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 15 ms
- Horizontal Viewing Angle
- 85
- Vertical Viewing Angle
- 85
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K
- OSD Languages
- English, German, French, Italian, Spanish
- Black
- 1U
- 15.5 kg
Input
KVM
- Max Resolution
- 1600 x 1200 @ 60 Hz
- 2 x USB , VGA , 2 x KVM (PS/2) , Audio line-in , DVI-I
- Cables Included
- 1 x USB cable , 1 x audio cable , 1 x VGA cable
- UL, FCC, RoHS
- Localisation
- United Kingdom
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £551.61 |
