Mount a server, network or telecommunications device vertically with this 1U wall-mountable rack. The RK119WALLV 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket offers a versatile storage solution allowing rackmount equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 1U bracket can be installed horizontally under a desk, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Perfect for SoHo (small office, home office) environments, the wallmount bracket features a sturdy steel design constructed to EIA-310 19in rack standards, and offers space-savings for environments lacking the footprint space for a full size server equipment rack. Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes are positioned at exactly 16in apart, matching standard construction framework.
Need more storage space? StarTech.com also offers a RK219WALLV 2U 19in Wallmount Bracket, a RK319WALLV 3U 19in Wallmount Bracket and a RK419WALLV "4U 19in Wallmount Bracket.
Durable steel construction
This mounting bracket is made of high-quality steel, ensuring strength for holding networking and data equipment securely. -
Space-efficient wall mounting
Designed to be mounted on walls, this bracket helps save valuable floor space while effectively organizing equipment in a vertical orientation. -
Standard 19-inch rack compatibility
Perfectly sized for standard 19-inch racks, this bracket allows for seamless integration with existing network setups and installations. -
Included mounting kit
The product comes with a complete mounting kit, making the installation process straightforward for users of all skill levels. -
Compliant with safety standards
This mount meets UL and RoHS compliant standards, ensuring adherence to quality and safety regulations for reliable performance.
 - StarTech.com 1U Wall Mount Patch Panel Bracket - 19 in - Steel - Vertical Mounting Bracket for Networking and Data Equipment (RK119WALLV) - mounting bracket - 1U
- Product Type
 - Mounting bracket
- Placing / Mounting
 - Wall mountable
 - Black
- Rack Size
 - 19"
- Height (Rack Units)
 - 1U
- Product Material
 - Steel
 - 5 cm x 6 cm x 15.1 cm
 - 0.66 kg
 - Limited lifetime warranty
- Designed For
 - P/N: SV831DUSBUK
- Product Type
 - Mounting bracket
 - Wall mountable
- Product Material
 - Steel
- Rack Size
 - 19"
 - 1U
 - 5 cm
 - 6 cm
 - 15.1 cm
 - 0.66 kg
 - Black
- Mounting Kit
 - Included
 - UL, RoHS
 - Limited warranty: - lifetime
- Designed For
 - P/N: SV831DUSBUK
                        StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.78 |
                        StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £40.61 |
                        StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
                        StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
                        StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £48.26 |
                        StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels | In Stock | £16.23 |
                        StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.39 |
                        StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
                        StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
                        StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
                        StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £129.80 |
                        StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £17.22 |
                        StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
                        StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
                        StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
                        StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
                        StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
                        StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
                        StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
                        StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
                        StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
                        StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £30.19 |
                        StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
                        StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.84 |
                        StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.45 |
                        StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
                        StarTech.com 4U WM Server Rack with Shelf | In Stock | £103.10 |
                        StarTech.com 8U WM Server Rack with Shelf | In Stock | £136.71 |
                        StarTech.com 6U Wall Mount Rack Bracket | In Stock | £64.77 |
                        StarTech.com 18U Server Rack Enclosure | In Stock | £369.77 |
                        StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
                        StarTech.com 26U Server Rack Enclosure | In Stock | £470.78 |
                        StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
                        StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
                        StarTech.com 12U Server Rack Enclosure | In Stock | £330.35 |
                        StarTech.com 12U Server Rack Enclosure | In Stock | £276.36 |
                        StarTech.com 15U Server Rack Enclosure | In Stock | £313.10 |
                        StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
                        StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.74 |
