StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9RWS00 Mfr#: RK119WALLV
Product Type: Mounting bracket
10 In Stock
£35.23 ex VAT
£42.27 inc VAT
Mount a server, network or telecommunications device vertically with this 1U wall-mountable rack. The RK119WALLV 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket offers a versatile storage solution allowing rackmount equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 1U bracket can be installed horizontally under a desk, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Perfect for SoHo (small office, home office) environments, the wallmount bracket features a sturdy steel design constructed to EIA-310 19in rack standards, and offers space-savings for environments lacking the footprint space for a full size server equipment rack. Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes are positioned at exactly 16in apart, matching standard construction framework.
Need more storage space? StarTech.com also offers a RK219WALLV 2U 19in Wallmount Bracket, a RK319WALLV 3U 19in Wallmount Bracket and a RK419WALLV "4U 19in Wallmount Bracket.
  • Durable steel construction
    This mounting bracket is made of high-quality steel, ensuring strength for holding networking and data equipment securely.
  • Space-efficient wall mounting
    Designed to be mounted on walls, this bracket helps save valuable floor space while effectively organizing equipment in a vertical orientation.
  • Standard 19-inch rack compatibility
    Perfectly sized for standard 19-inch racks, this bracket allows for seamless integration with existing network setups and installations.
  • Included mounting kit
    The product comes with a complete mounting kit, making the installation process straightforward for users of all skill levels.
  • Compliant with safety standards
    This mount meets UL and RoHS compliant standards, ensuring adherence to quality and safety regulations for reliable performance.
StarTech.com 1U Wall Mount Patch Panel Bracket - 19 in - Steel - Vertical Mounting Bracket for Networking and Data Equipment (RK119WALLV) - mounting bracket - 1U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
1U
Product Material
Steel
5 cm x 6 cm x 15.1 cm
0.66 kg
P/N: SV831DUSBUK
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
1U
5 cm
6 cm
15.1 cm
0.66 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
P/N: SV831DUSBUK
6B9R StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.23
6B9R StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
6B9R StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
6B9R StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.44
6B9R StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.26
6B9R StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.23
6B9R StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.09
6B9R StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.55
6B9R StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
6B9R StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
6B9R StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £129.80
6B9R StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
6B9R StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
6B9R StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.83
6B9R StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.41
6B9R StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
6B9R StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
6B9R StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
6B9R StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
6B9R StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
6B9R StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
6B9R StarTech.com 100 Pkg M5 Mounting Screws In Stock £30.51
6B9R StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
6B9R StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.35
6B9R StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
6B9R StarTech.com 19in Cable Management Panel In Stock £23.21
6B9R StarTech.com 4U WM Server Rack with Shelf In Stock £103.10
6B9R StarTech.com 6U Wall Mount Rack Bracket In Stock £64.77
6B9R StarTech.com 18U Server Rack Enclosure In Stock £369.77
6B9R StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
6B9R StarTech.com 26U Server Rack Enclosure In Stock £463.46
6B9R StarTech.com 9U Wall-Mount Rack Cabinet In Stock £179.09
6B9R StarTech.com 9U Wall-Mount Rack Cabinet In Stock £193.99
6B9R StarTech.com 12U Server Rack Enclosure In Stock £330.35
6B9R StarTech.com 12U Server Rack Enclosure In Stock £276.36
6B9R StarTech.com 15U Server Rack Enclosure In Stock £313.10
6B9R StarTech.com 12U Server Rack Enclosure In Stock £375.79
6B9R StarTech.com M6 Mounting Screws 50Pack In Stock £16.16
