Organize your LAN's twisted-pair cabling and provide increased stability to your work environment with StarTech.com's hinged WALLMOUNTH1, a 1U (1.75") steel mounting bracket that holds 19" rack equipment in place by screwing into a wall.
- StarTech.com 1U Hinged Wall Mount Patch Panel Bracket - 4 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 17lbs (WALLMOUNTH1) - wall mount bracket - 1U - 19"
- Product Type
- Wall mount bracket
- 48.3 cm x 10.2 cm x 4.5 cm
- 0.4 kg
- Product Material
- Steel
- Height (Rack Units)
- 1U
- 1-year warranty
- Designed For
- P/N: PANEL4524
- Product Type
- Product Material
- Steel
- 1U
- 48.3 cm
- 10.2 cm
- 4.5 cm
- 0.4 kg
- Rack Size
- 19"
- Rack Mounting Kit
- Included
- Limited warranty - 1 year
- Designed For
- P/N: PANEL4524
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £37.95 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £42.34 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.98 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £41.24 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £54.20 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £70.01 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.34 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £31.00 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.51 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.56 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.09 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.23 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £131.41 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £57.99 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.93 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £26.91 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £29.11 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £15.59 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £54.01 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.53 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £16.04 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.99 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.75 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.84 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £28.49 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £35.79 |
StarTech.com 18U Server Rack Enclosure | In Stock | £383.80 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £481.62 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
StarTech.com 12U Server Rack Enclosure | In Stock | £343.41 |
StarTech.com 12U Server Rack Enclosure | In Stock | £276.36 |
StarTech.com 15U Server Rack Enclosure | In Stock | £324.97 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £27.14 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.78 |
