Organize your LAN's twisted-pair cabling and provide increased stability to your work environment with StarTech.com's hinged WALLMOUNTH1, a 1U (1.75") steel mounting bracket that holds 19" rack equipment in place by screwing into a wall.
- StarTech.com 1U Hinged Wall Mount Patch Panel Bracket - 4 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 17lbs (WALLMOUNTH1) - wall mount bracket - 1U - 19"
- Product Type
- Wall mount bracket
- 48.3 cm x 10.2 cm x 4.5 cm
- 0.4 kg
- Product Material
- Steel
- Height (Rack Units)
- 1U
- 1-year warranty
- Designed For
- P/N: PANEL4524
- Product Type
- Product Material
- Steel
- 1U
- 48.3 cm
- 10.2 cm
- 4.5 cm
- 0.4 kg
- Rack Size
- 19"
- Rack Mounting Kit
- Included
- Limited warranty - 1 year
- Designed For
- P/N: PANEL4524
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £36.68 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.63 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.52 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £40.62 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £54.83 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £68.51 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £35.14 |
StarTech.com 18U Server Rack Enclosure | In Stock | £379.01 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £152.72 |
StarTech.com 26U Server Rack Enclosure | In Stock | £475.05 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £178.89 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £198.84 |
StarTech.com 12U Server Rack Enclosure | In Stock | £338.60 |
StarTech.com 12U Server Rack Enclosure | In Stock | £283.26 |
StarTech.com 12U Server Rack Enclosure | In Stock | £393.13 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £26.77 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
