StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels
Quicklinx: 7B8CWS00 Mfr#: WALLMOUNTH1
Product Type: Wall mount bracket
£16.64 ex VAT
£19.96 inc VAT
Organize your LAN's twisted-pair cabling and provide increased stability to your work environment with StarTech.com's hinged WALLMOUNTH1, a 1U (1.75") steel mounting bracket that holds 19" rack equipment in place by screwing into a wall.
StarTech.com 1U Hinged Wall Mount Patch Panel Bracket - 4 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 17lbs (WALLMOUNTH1) - wall mount bracket - 1U - 19"
Wall mount bracket
48.3 cm x 10.2 cm x 4.5 cm
0.4 kg
Product Material
Steel
Height (Rack Units)
1U
1-year warranty
P/N: PANEL4524
Wall mount bracket
Product Material
Steel
Height (Rack Units)
1U
48.3 cm
10.2 cm
4.5 cm
0.4 kg
Rack Size
19"
Rack Mounting Kit
Included
Limited warranty - 1 year
P/N: PANEL4524
7B8C StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.68
7B8C StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
7B8C StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7B8C StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.62
7B8C StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.83
7B8C StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
7B8C StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7B8C StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7B8C StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7B8C StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7B8C StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7B8C StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
7B8C StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7B8C StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
7B8C StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7B8C StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7B8C StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7B8C StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7B8C StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7B8C StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7B8C StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7B8C StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
7B8C StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7B8C StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
7B8C StarTech.com 18U Server Rack Enclosure In Stock £379.01
7B8C StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
7B8C StarTech.com 26U Server Rack Enclosure In Stock £475.05
7B8C StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
7B8C StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
7B8C StarTech.com 12U Server Rack Enclosure In Stock £338.60
7B8C StarTech.com 12U Server Rack Enclosure In Stock £283.26
7B8C StarTech.com 15U Server Rack Enclosure In Stock £336.37
7B8C StarTech.com 12U Server Rack Enclosure In Stock £393.13
7B8C StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
7B8C StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
