StarTech.com 1U 17" HD 1080p Rackmount LCD Console with Front USB Hub
Quicklinx: 9KZFWS00 Mfr#: RKCONS17HDGB
Control server equipment from a centralized, Full HD KVM console. The RKCONS17HDGB 17" Full HD LCD Rack Console lets you control server equipment from a centralized, 17in 1080p KVM console, with an integrated 2-port front USB hub.
The integrated single port KVM module offers universal support for DVI or VGA, and USB or PS/2 console connections and includes all of the necessary cabling to get you up and running. Connect the console to either a single system, or a multi-port KVM switch to manage multiple systems.
The front panel USB hub places two easily accessible USB 2.0 ports at your disposal for connecting external storage and other peripherals as needed.
For added security in your server room, this rackmount LCD also includes a physical key-lock.
StarTech.com 1U 17" HD 1080p Rackmount LCD Console with Front USB Hub - KVM console - Full HD (1080p) - 17"
KVM console - 17"
KVM Switch
PS/2, USB
Keyboard, touchpad
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
650:1
Colour Support
16.7 million colours
Input Connectors
DVI-I, VGA
Voltage
AC 120/230 V
44.8 cm x 46 cm x 4.4 cm
Height (Rack Units)
1U
13 kg
United Kingdom
FCC, RoHS
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
650:1
Colour Support
Horizontal Viewing Angle
140
Vertical Viewing Angle
120
Backlight Technology
LED backlight
Height (Rack Units)
1U
13 kg
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1920 x 1080 / 1080p
2 x USB 2.0 (Type A) , Keyboard (PS/2) , Mouse (PS/2) , Keyboard (USB) , Mouse (USB) , DVI-I , VGA (HD-15)
Key lock
1 x USB cable - 1.8 m , 1 x keyboard / mouse / video cable - 1.8 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
FCC, RoHS
United Kingdom
Power Supply
External
Input Voltage
AC 120/230 V
Power Consumption (Typical)
23.35 Watt
50 °C
10 - 90%
9KZF StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £551.61
9KZF StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £292.39
