Charge or sync your Micro USB devices, with this high-quality white USB 2.0 replacement cable. The USBPAUB1MW 1m White USB to Micro USB Cable features thin USB connector moldings and provides a simpler connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
- StarTech.com 3.3 ft. (1 m) USB to Micro USB Cable - USB 2.0 A to Micro B - White - Micro USB Cable (USBPAUB1MW) - USB cable - Micro-USB Type B to USB - 1 m
- USB cable
- Technology
- Double shielded
- Molded, strain relief
- Length
- 1 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- White
- Limited lifetime warranty
- Designed For
- P/N: USBEXTPAA1MW, USBEXTPAA2MW, USBEXTPAA3MW, USBPAUB2MW, USBPAUB50CMW
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- White
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.30 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.25 |
StarTech.com 2m White Micro USB Cable - A to Micro B | In Stock | £7.20 |
StarTech.com 0.5m White Micro USB Cable - A to Micro B | In Stock | £5.12 |
