StarTech.com 1m White Micro USB Cable - A to Micro B
Quicklinx: 9208WS00 Mfr#: USBPAUB1MW
Charge or sync your Micro USB devices, with this high-quality white USB 2.0 replacement cable. The USBPAUB1MW 1m White USB to Micro USB Cable features thin USB connector moldings and provides a simpler connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
  • Reliable construction
    Double shielded technology provides protection against interference, ensuring consistent data transfer rates.
  • Durable design
    With molded construction, this cable is built to withstand daily wear and tear, suitable for regular use.
  • Convenient length
    The compact 3.3 ft. length allows for easy connection in tight spaces, making this cable a practical solution for home or office environments.
  • Easy compatibility
    This cable is compatible with a wide range of devices utilizing USB 2.0 and Micro USB connections, enhancing versatility.
  • Strain relief feature
    Designed with strain relief, this cable minimizes the risk of fraying and breaking at the connectors, extending its lifespan.
StarTech.com 3.3 ft. (1 m) USB to Micro USB Cable - USB 2.0 A to Micro B - White - Micro USB Cable (USBPAUB1MW) - USB cable - Micro-USB Type B to USB - 1 m
USB cable
Double shielded
Molded, strain relief
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
P/N: USBEXTPAA1MW, USBEXTPAA2MW, USBEXTPAA3MW, USBPAUB2MW, USBPAUB50CMW
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
White
Connector
USB / USB 2.0, RoHS
9208 StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.37
9208 StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
9208 StarTech.com 0.5m White Micro USB Cable - A to Micro B In Stock £5.13
