The StarTech.com 1m (3.3ft) USB4 Cable is a high-performance USB-C cable designed to meet the needs of data and power users. Certified by USB-IF, this cable supports a data rate of 40 Gbps and offers features such as DisplayPort Alternate Mode 1.4, HDR support, and up to 240 watts of power delivery. Whether you're transferring large files, charging your devices, or connecting to high-resolution displays, this cable ensures efficient and reliable performance. Its EMI protection and durable, eco-friendly design make it a smart choice for both professional and personal use. With support for both 8K60Hz and 4K120Hz video, it's suitable for video editors, gamers, and anyone who requires high-quality video output. Additionally, its compliance with FCC, RoHS, and USB-IF standards ensures that it's a safe and responsible choice for your connectivity needs.
High-speed connectivity
Experience data transfer speeds of up to 40 Gbps with the StarTech.com USB4 cable, enabling quick file transfers and efficient work processes. -
Advanced display support
With DisplayPort Alternate Mode 1.4 support, HDR, and Display Stream Compression (DSC), this cable is capable of delivering high-resolution video up to 8K60Hz and 4K120Hz, suitable for professional video editing and high-definition entertainment. -
Enhanced power delivery
Supporting up to 240 watts of power delivery through Power Delivery 3.1, this cable can charge laptops, tablets, and other devices quickly, reducing downtime and keeping you productive. -
Durable and eco-friendly design
Constructed with a thermoplastic elastomer (TPE) jacket and featuring halogen-free materials, the cable is designed for durability while being environmentally friendly. The presence of an e-marker chip and strain relief further ensures a reliable connection and extended lifespan.
- StarTech.com 1m (3.3ft) USB4 Cable, USB-IF Certified USB-C Cable, 40 Gbps - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Coaxial
- Halogen-free, passive cable, 4K120Hz support, 8K60Hz support, extended power range (EPR), Power Delivery 3.1 support, strain relief, EMI protection, e-marker chip, HDR support, 32 audio channels, High Bit Rate 3 (HBR3), 40 Gbps data rate, Display Stream Compression (DSC), up to 240 Watts of power delivery, DisplayPort Alternate Mode 1.4 support
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4
- Black
- 2-year warranty
- USB-C cable
- Technology
- Coaxial
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 4.8 mm
- Black
- 46 g
- Connector
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4, FCC, RoHS, USB-IF
- Shipping Width
- 13 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.3 cm
- Shipping Weight
- 52 g
- 2-year warranty
