Power your 5V DC devices from your computer through a USB port. Tired of having to carry around a separate wall adapter in order to power or charge your 5V devices, such as certain external hard drives, streaming media players, and Bluetooth speakers?
This 1m USB power cable makes it easier to power 5V DC devices that have a Type N barrel power connector. You can power or charge the devices through an available USB port on your laptop or desktop computer.
                Durable constructionThe molded design of this power cable enhances its durability, allowing it to endure regular wear and tear over time.
                Flexible usageAt 1 m in length, this cable provides ample length for connecting devices without hindering movement or creating a cluttered workspace.
                Reliable connectionsWith a 4-pin USB Type-A male connector on one end and a male 5.5 mm DC jack on the other, the cable ensures a secure and stable power connection for various applications.
                Environmentally friendlyThis cable is RoHS compliant, indicating that it adheres to safety standards that limit hazardous substances, promoting safer usage.
- StarTech.com 1m USB to Type N Barrel 5V DC Power Cable - USB A to 5.5mm DC - 1 Meter USB to 5.5mm DC Plug (USB2TYPEN1M) - power cable - USB (power only) to DC jack 5.5 x 2.5 mm - 1 m
- Power cable
- Technology
- Shielded
- Molded, strain relief
- Length
- 1 m
- Connector
- 4 pin USB Type A (power only) - male
- Connector (Second End)
- Power DC jack 5.5 mm (ID: 2.5 mm) - male
- Black
- Limited lifetime warranty
- Designed For
- P/N: HDBOOST
- Power cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- RoHS
- Designed For
- P/N: HDBOOST
